  • SN95 4.6L Mustang Tech
have question, replacing plenum
  • Thread starter Thread starter baller760
  • Start date Start date Oct 29, 2004
baller760
98
So. Cal.
Oct 29, 2004
  • Oct 29, 2004
I took off the plenum and undid all the connections except one. I think it's the pcv valve. Anyway, there's a hose that connects to it which connects to a valve cover it seems? Anyway, I can't get it off of the plenum! It's stuck. It won't budge. When I pull it looks like the hose is going to break! What do I do?
tomustang
Psychotic Member
3,434
McLean Hospital
Oct 29, 2004
  • Oct 29, 2004
disconnect the hose from the valve cover, take the plenum off with the hose.
showstopper2
425
New Bedford, Ma.
Oct 29, 2004
  • Oct 29, 2004
use a screwdriver to pry the hose off the plenum. they get heated onto the metal over time and won't come off unless you pry them.
M
Makalani_96GT
159
SoCal
Oct 29, 2004
  • Oct 29, 2004
Take the pcv off with the hose connected then get a ride to your local dealership and get a new one for ten bucks. Do you really think that when you pry it off with something it isn't going to leak later on? Plus when I ran into the same problem and got a new one form the dealer it was glued to the pcv
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
M
  • mnky99
  • Sep 5, 2025
mnky99
M
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
  • Gulftown980x
  • Jul 29, 2026
squeak93
