Have to hold key on to keep it runing
  • Thread starter Thread starter Farmers SN95
  • Start date Start date Jul 15, 2007
Farmers SN95
76
Ky
Jul 15, 2007
  • Jul 15, 2007
On my 89 (4 to 5.0) I have to hold the key on (like starteing) to keep it run.
any one know some thing to try let me know.
thanks
Zack
88mouse
630
Mooresville nc
Jul 15, 2007
  • Jul 15, 2007
the key switch is broke the electrical part of it.
Farmers SN95
76
Ky
Jul 15, 2007
  • Jul 15, 2007
I will try that, but it was working fine when the car had the 2.3, but then I put the 5.0 in you have to hold the key on, to keep it runing.
thanks
Zack
93 LX
3,081
Norwalk, CA.
Jul 15, 2007
  • Jul 15, 2007
sounds like you miswired the run circuit
Mustank
166
Germany
Jul 16, 2007
  • Jul 16, 2007
Bad ignition switch will do the same thing sometimes before it breaks completely. It happened to me on the way home from work one day and I had to hold the key for about 10 minutes to get home. It would still start and run as long as I held the key in the "start" position but the ignition switch eventually came completely apart.
It's a pretty common problem with foxes. I even ordered an extra one when I got my new fox, just in case.
conartist
77
Windsor, Ontario, Canada
Jul 16, 2007
  • Jul 16, 2007
Ignition switch, I'll bet, happened to me before.
D
DE Ride
  • Jul 16, 2007
Either you wired it wrong, or the switch is on its way out. Issues often pop up when you do major work.change things around.
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Jul 16, 2007
  • Jul 16, 2007
+1, ignition switch
D
DE Ride
  • Jul 16, 2007
Is there any wiring needed that could cause this issue at all with the swap anyway?
Farmers SN95
76
Ky
Jul 16, 2007
#10
  • Jul 16, 2007
  • #10
I will try the ignition switch, one day I am off work.
thanks
Zack
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Jul 17, 2007
#11
  • Jul 17, 2007
  • #11
If it's not the switch, then there are two 12v wires that go to the TFI. One is on in "crank" (TFI pin #4) and the other is on in "run" (TFI pin #3).
Farmers SN95
76
Ky
Jul 17, 2007
#12
  • Jul 17, 2007
  • #12
I got it runing, it was the Ignition switch, now I just need to put 8.8 in the car and finish it.
Thanks everyone
Zack
  • brandyn200
  • Jun 20, 2026
AeroCoupe
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
L
2000 Mustang PATS - Broken Key and Wire - HELP!
  • Laree Taylor
  • May 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
manicmechanic007
