HCI Install done... Car wont start!
finished putting everything back together and turned the key to the on position then the coil fried. got a new coil, new module (mounted on distributor), and tried to start the engine... there is power going into the coil but no spark coming out. also i have no fuel pressure, knodont w if that is related or not. i am so pissed off right now and i ran out of money to take it to a mechanic! help would be great if u guys know what i should check for
did you install your 255 walbro at the same time as the coil??? if so check to see that the pump is getting voltage and has a good groud for the fuel prob....then check for a short to ground on the primary side of the coil......if you have power to the coil but no spark...and you recently fried your prievious coil...you must have a short to ground somewhere on the coil primary side (power to coil and ground, not coil to distributor wire)...use a multimeter if you have one....good luck!
