In this sequal to the Mud In #4 Cylinder of the 302 V8 post I decide to do the leak test on the heads while I have them off. I flip the heads upside down and set them down so they are level on a dry piece of cardboad, then I used to poor water in the combustion chambers but that takes all night to find leaks, so I used gasoline this time [as my friend says please don't try this at work]. As it turns out the passenger head above the muddy cylinder is fine, however the head on the opposite side, ie the driver side leakes like a sift.
Now before you sworm me with why are you so masochistic, do it right, send the heads to a machine shop posts, or better yet toss these SMOG era junkers all together, I need to let you know that I am not going to end up using these heads in the long run, they are just to cut my teeth on and practice, I do have a set of E7TE heads off of a 5.0 Mustang but that's another post, and yes I know there are better heads than those also, lol.
So in order to put on the good head on the passenger side do I do anything fancy with the gasket, I know knowing the front and back is important, but do I put any type of gunk on it?
I got the flanged bolts so I am going to torque the top ones to 80 ft lbs and the bottom ones to 70 ft lbs that's what the gasket instructions say to do following the start in the middle and work your way out sequence.
As far as the leaky head the plan is to take the valves out one at a time and clean the crud out of there with brake cleaner and a steel brush, then put them back in, and re-test.
