Head bolt did not torque down
  • Thread starter Thread starter Stormwalker
  • Start date Start date Jul 22, 2005
Stormwalker
Not a New Member
Nov 19, 2003
83
Ft Ripley, MN
Jul 22, 2005
  • Jul 22, 2005
When I took off my heads, one of the head bolts snapped off in the block. It actually felt loose immediately when I began to torque it off, like it was sitting in there loose before I touched it, and sure enough, it was broken. To make a long story short, I resorted to using a heli coil kit (Napa's "head bolt repair kit"). When I torqued the new bolts down on the new heads, the heli-coiled bolt only got to 50 ft/lbs, unlike the 75 ft/lbs needed. After that, it just spun and did not get any tighter. Obviously, this is not good, I want a good reliable car, not one that will blow head gaskets and such.
What are my options here? Do I have to get an entirely new block? Let me know what you think, thanks.
z2o_what
309
princeton, WV
Jul 22, 2005
  • Jul 22, 2005
you could probally get the hole rethreaded
R
ratrapp2
121
  • Jul 22, 2005
i had this problem in my 88 when i first got it.somebody helicored several headbolt holes.my car kept having weird overheating problems.would go days without overheating then it would puke for no reason.turns out the block was cracked where the headbolts went.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 22, 2005
  • Jul 22, 2005
If you helicoiled one of the short lower bolts, the helicoil may have spun down into the water jacket. Remove the helicoil and apply some permanent grade Locktite to a new helicoil and install it. Let it harden according to the Locktite package directions prior to installing the head.
On all the short bolts, use teflon pipe dope (hardware store or Home Depot item) on the bolt threads, and anti-seize under the bolt heads. Use lots of anti-seize on the long bolts under the bolt heads and on the threads.
Stormwalker
Not a New Member
Nov 19, 2003
83
Ft Ripley, MN
Jul 22, 2005
  • Jul 22, 2005
Can you elaborate on this?
Stormwalker
Not a New Member
Nov 19, 2003
83
Ft Ripley, MN
Jul 22, 2005
  • Jul 22, 2005
It was indeed one of the short lower bolts. I used the red high strength loctite and let it cure for over 24 hours. I also used the teflon liquid thread sealer on all of the lower bolts. And I even used anti-seize where the head bushings contact the head (I am using Edelbrock performer heads, so it requires me to use the Edelbrock bushing kit instead of the washers that came with the ARP bolts or whatever). Good to know that I am at least doing some things right. The ARP bolts came with instructions as well, and just said to use 30 weight motor oil on the long bolt threads, and not anti-seize, because it would throw the torque readings off, so I just used the oil on the long bolt threads.
When I initially torqued the bolt to 30, it was getting tighter, and then let loose and spun easily. I knew the heli coil let loose at that point, and just kept turning it. It caught again and torqued to 50 before it started to let go again. I think what happened is I put the heli coil halfway down, and when it initiallly started spinning, it rode up the hole towards the head, and finally ended up butted against the head, where it caught again and was able to torque to 50. However, it started spinning again, which could only mean that the hole ended up slightly larger than it was supposed to be, which is entirely my fault.
So I have already followed the directions, and your advice, to a tee when I initally tried this. Now what?
I am probably going to take it in somewhere to see what a shop says. I am the one that screwed this up, and since my efforts at repair have failed, I should let someone more experienced try to fix my mistakes. Will a shop be able to do anything for me? Or would someone recommend that I try one last thing? It will not be fun to move the car anywhere at this point.
z2o_what
309
princeton, WV
Jul 22, 2005
  • Jul 22, 2005
if your threads in the block are stripped, you could take it to a machine shop and have them rethead the holes.......or, you could do it yourself if you have the tool
Stormwalker
Not a New Member
Nov 19, 2003
83
Ft Ripley, MN
Jul 22, 2005
  • Jul 22, 2005
Alright, so what you are saying is that they can put metal back inside the block?
Stormwalker
Not a New Member
Nov 19, 2003
83
Ft Ripley, MN
Jul 22, 2005
  • Jul 22, 2005
I take it that because no one is replying, no one wants to be the harbringer of the news that I need a new block.
M
MarSaleenMustan
208
San Bernardino California
Jul 22, 2005
#10
  • Jul 22, 2005
  • #10
belive it or not you'd probably be a little better off getting a new short block... you can probably get one for under 1K freshly rebuilt and all from a local engine shop and bolt everything up, that way you have a fresh block and dont have that helicoil deal in the back of your mind even if you get it fixed.... that or if money is real tight go to a junk yard, find a wrecked car with a 5.0 H0 motor and buy the short block from there and put it in your car. you can probalby get one(if you find it of course) for around 150 or so for the short block, which is really all you need.
vikingpower
656
CWU Ellensburg, WA
Jul 22, 2005
#11
  • Jul 22, 2005
  • #11
call a (performance oriented) machine shop and see what they can do, they should be able to fix it right up
Stormwalker
Not a New Member
Nov 19, 2003
83
Ft Ripley, MN
Jul 22, 2005
#12
  • Jul 22, 2005
  • #12
A member of the local mustang club suggested something interesting to try. Perhaps a head stud is the answer, since it is less of a twisting torque so to speak, and more of an upwards lifting torque. I might give that a shot.
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
  • dan50
  • Jul 18, 2026
dan50
