My new 351 has only 20 miles on it and all is well except a minor oil leak which seems to becoming from a head bolt? does this make sense? Thanks, Norm
Check the valve covers, or the intake at the front and rear. It's possible the head gaskets it leaking, but more tan likely the gasket you used, not really likely.
Yeah. I have less experience with 351 blocks, but if his was a 351 roller block, then I was suspicious of him using a front cover-type dipstick and not plugging the hole in the block for block/pan rail mounted dipstick. It wouldn't be the first time.
