  • 1994 - 1995 Specific Tech
Head bolts?
  • Thread starter Thread starter sl03gt
  • Start date Start date Feb 26, 2007
sl03gt
20+ Year Stangneter
Sep 29, 2003
182
Feb 26, 2007
  • Feb 26, 2007
Going to be swapping heads on a stock 94. Replacing with stock heads can you reuse the head bolts? Just curious.
M
MustangGT95
407
  • Feb 26, 2007
You can but it isn't recommended.
T
tjh566
608
Northern Va
Feb 26, 2007
  • Feb 26, 2007
Ive always been told to use new ones.
BlackVert
5,589
9
98
Bethesda, MD
Feb 26, 2007
  • Feb 26, 2007
you are not supposed to reuse head bolts. apparently they are designed to stretch when you torque them down
i'm 95% sure that if you use head studs, you can resue them. the ones i have (arp) screw into the block with an allen wrench. that way you can take them out if you need to the next time you change heads.
sl03gt
20+ Year Stangneter
Sep 29, 2003
182
Feb 26, 2007
  • Feb 26, 2007
Just curious, that's what I thought. Thanks
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Feb 26, 2007
  • Feb 26, 2007
You can reuse ARP head bolts and ARP studs, the latter more so.
If you were on a serious budget, you could technically use the stock head bolts. They will still clamp, but it isn't recommended.
I have used my ARP head bolts 3 times now. Not worried about them at all.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Feb 26, 2007
  • Feb 26, 2007
Cough up the dough and do it right, just get some arp bolts.
Scott
M
Broken lower intake bolts
  • Mike3
  • Aug 11, 2025
1994 - 1995 Specific Tech Sep 2, 2025
revhead347
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
393W Stroker with Boost - Need Spark Plug Recommendations
  • 387lx
  • Apr 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 30, 2026
HotFox
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
