Going to change the head gasket this weekend and want to make sure I have diagnosed it correctly (have owned '65 with 6cyl for 5 weeks now).
Bought the car with lower compression on the back two cylinders, was pretty sure it was a head gasket as the rest of the cylinders have great compression and it burned no oil.
Have driven it daily for 5 weeks now to work (40 minutes each way). Ran rough two weeks ago and the plugs were changed as most were coated in oil and probably had one or two not firing. After plugs were changed it ran great! Now power is way down, leaking oil a bit on the back of motor (never leaked before), and can see burning oil on hard takeoff (never burned oil before). I bet the plugs are starting to coat up again...
Does sound like head gasket only? I am pretty sure it is but don't want to change the gasket if oil is burning by the rings. What should I look for (pistons/ rings) when I have the head off? Need help befoe the big cruise on June 5. Thanks!!
