Head gasket question!
pedro
432
Hey guys, what's up? Nothing new here, just about 40°C ('bout 104°F :P). Well I've got a question. Are head gaskets for Rangers, Aerostars and Mustangs the same? Anything commments, recommendations or something I should know before buying this. You're the experts! :D
OK, thanks a lot for your time, see ya!
They should be the same regardless of application. I don't know if the dual plug or other heads have some weird deal though.
make sure the 2 block dowels are in good condition and no junk in dowel holes. After you get all the gasket material off and clean out the cylinders, thoroughly rinse both block and head surfaces with ether starting fluid and a clean rag. Also bring all the pistons even and apply some gear oil round them along the walls, so it seeps into the rings to lube them since you were in there getting dirt and solvent in it.
put gasket and head on... have all head bolts nice n clean (assume you cleaned out block threads too) and put 2 in the middle DRY and make them tight with a regular ratchet. Then put the rest of the bolts in, with oil on threads, make them snug. Then take out the first 2 and lube. I don't know of anyone that does this but in any event it will prevent oil from squeezing out the threads all over the gasket.
Hey guys! Thanks for your quick replies, I reallye appreciate. Ray III thanks for the explanation, I'm gonna print it, it will come handy. :) I'm gonna change this thing with some help from my dad (he's a car nut :P). So, are there any other recommendations or things I should know?
