Head I.D.
  • Thread starter Thread starter NKau
  • Start date Start date Aug 15, 2005
NKau
1,346
Jefferson, WI
Aug 15, 2005
  • Aug 15, 2005
Rocker Arm/Head I.D. (pics)
I'm having some trouble trying to run down rocker arms for my '65. The numbers stamped in the heads read '7F22' with '4V' under it, as well as '302' cast into them. They are obviously 302 4V heads, but from what? The rockers on them are different from anything I can find on 70's/80's truck and car heads. Anyone know what I have here?
Dark Knight
2,578
Chandler, Az.
Aug 15, 2005
  • Aug 15, 2005
look for the casting number, should be under the intake ports..
pretty sure there are only 3 kinds of factory rockers, early flat type, ones with rails to line the rocker and pedestal mount where the bolt goes thru the rocker amr and pedestal and bolts them to the head
NKau
1,346
Jefferson, WI
Aug 15, 2005
  • Aug 15, 2005
pics of heads/rockers
Just want to know what these rockers come on; what I can pick them off of at the junkyard, as I have a broken one that needs replacement. Would also be nice to know what the heads are. Thanks for any help guys. (sorry for pic sizes)
9
96 DOHC Cobra
542
Cerritos, CA
Aug 16, 2005
  • Aug 16, 2005
The rockers look like standard "rail" type rockers. they can be found on any 289, 302, or 351W from about 1966 to about 1978. The heads are 1968 "J Code" heads (302 with four barrel carb). They were available that year only. They had very small combustion chambers for high compression.
D
D.Hearne
11,730
south louisiana
Aug 16, 2005
  • Aug 16, 2005
Ditto--------- you've got a set of 68-302 4 bbl heads with rail rockers. Basically the same head as the earlier C6OE 289 head, but with rail rockers.
NKau
1,346
Jefferson, WI
Aug 16, 2005
  • Aug 16, 2005
Hey, thanks a bunch guys. Nice to know what rocker arms I need, and that the heads sound like keepers. Thanks again.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
SN95 New Heads
  • Blakeknight
  • May 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2025
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
