Ive got a fox body and it has everything for lights besides headlights!!!! What could it be??? A turn signal switch???
Agreed. Check the headlight feed wire into the MF switch (it's red/yellow IIRC on the early aero foxes). While inspecting it, be sure it has power (when the headlight switch is in position 2).
Does your flash-to-pass function ok? If so, the issue should be before the MF switch.
Good luck.
Sorry But im not sure what "FLASH-TO-PASS" Function is but if its the flashers then yeah they work. before they stopped working u could move the blinker switch around and they would sometimes come on but now they dont.....![]()
When you pull back (towards you, as you sit in the driver's seat) on the turn-signal stalk, the high and low beams should illuminate as long as you keep the stalk pulled back.
If FTP functions ok, the wiring from the output of the MF switch [going to the lights] is ok.
Your thinking is sound. The MF switch is where I'd start with the diagnostics for all the issues.Resurrection!
Before I go poking and prodding at the wires (which I will anyways), on start up and every say, 5 minutes or more my wipers sweep once and repeat this cycle, along with my headlights not working which were replaced for some bright blue ones it looks like.
Sound like the MF? and no my FTP doesn't work with headlights switch clicked on or off.
Or do you guys, think the wiper issue is unrelated?
