Head Question
  • Thread starter Thread starter 67GTA-FB429
  • Start date Start date Jan 28, 2004
67GTA-FB429
777
Tri-Cities, Wa
Jan 28, 2004
  • Jan 28, 2004
This is an easy one. Where do I find the casting number on my cylinder heads?
Thanks.
crushnut
870
Oregon
Jan 28, 2004
  • Jan 28, 2004
They should be on the under side of the exhaust ports, a mirror is usefull if they are still bolted on the engine.
67GTA-FB429
777
Tri-Cities, Wa
Jan 29, 2004
  • Jan 29, 2004
Thanks. I nice convienent spot. I guess I can practice yoga this weekend.
crushnut
870
Oregon
Jan 29, 2004
  • Jan 29, 2004
D
D.Hearne
11,730
south louisiana
Jan 29, 2004
  • Jan 29, 2004
Depends on what heads you're looking at. If you're talking about the heads on your 429, then they're outside the valve cover rail, just above the exhaust ports. Small blocks are under the intake ports. FE's are outside between the center two exhaust ports.
67GTA-FB429
777
Tri-Cities, Wa
Jan 29, 2004
  • Jan 29, 2004
OK. While I put on new valve covers I will look for it. Then I will have some more questions about it.
Have you ever seen a Chevy big block in a Camaro? There is so much room under there it is not even funny. I was at a friends house checking out his Yenko clone, and actually got jealous.
67GTA-FB429
777
Tri-Cities, Wa
Jan 29, 2004
  • Jan 29, 2004
OK. Here are the casting numbers I saw...
C9VE-A
D0VE-C
Please let me know what that means.
I am scared that someone will say "it means you are *****ed".
D
D.Hearne
11,730
south louisiana
Jan 29, 2004
  • Jan 29, 2004
Those are good heads, While they both have different casting#'s they're basically the same head. Small combustion chambers, and screw in studs ( but the positive stop type) According to what I've read, if you have the CJ sized valves installed and port match them to the CJ intakes and exhaust, they actually flow better than the CJ heads did. One is a 69 head, the other a 70 head.
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Clearance
  • 1993mustang50
  • Apr 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 4, 2026
2000xp8
Engine Felpro 9333 pt1 (with 8psi boost)
  • JD1964
  • Jan 14, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
Qtrhrse23
9
Engine 2.3 fox body upgrades from sn95
  • 92ponyboy
  • Feb 20, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 25, 2026
NXcoupe
N
D
Negative Grounds for 2008 4.0L
  • deadbeat
  • May 13, 2026
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech May 13, 2026
deadbeat
D
