head question
wlink1
Banned
Apr 12, 2007
69
Winston Salem
How would these heads compare to the E7 and GT40.
1966 289 Hi-Po Heads C60E 54cc 1.67/1.45 Stainless Steel Valves With Screw In Studs And Heavy Duty Springs Worked Fine On a 302 +.30 With a Comp Cam .541/.544
1.67" intake valve? That thing's tiny! Even the E7 heads have a 1.78" intake valve stock. I'd pass on them. Pick up some GT40 or GT40P heads if you're working on a budget.
A L L Ford iron heads have poor exhaust ports :notnice:
The older 289-302 heads on carb equipped motors had smaller valves
as mentioned :bang:
Even though the E7,40, &40p heads have the same poo poo e ports :(
At least they don't have the tiny valve size ;)
Stick with the newer technology iron heads :)
or better yet :banana:
Keep feeding the piggy bank :nice:
for the latest technology Aluminum heads like TFS, AFR, & Edel :Word:
Grady
http://users.erols.com/srweiss/tablehdc.htm#Ford
Go down to the Windsor section for some Hi-Po flow numbers. Not very good...
In 1964, the Hi-Po heads went with the 'traditional' 1.78" intake valve size.:shrug: What year are yours?
According to the charts, it flows a bit better than a stock E7 head, but the Hi-Po's in question in that link have a 1.78" intake valve:shrug:
Your looking at rough numbers of 170cfm on the intake/121 cfm on the exhaust, compared to the stock e7 heads of 159/109.
The lift of a cam doesn't determine the cam's powerband to much. What is the comp cam's powerband you have picked out? Part number?
Is the cam?: FW XE284H-10 (powerband 2,300-6,500) aka: part numbers - CCA-31-250-4 and CCA-35-250-4.
.541/.544"
240/246 Duration at .050"
110 LSA
If that is indeed the camshaft, I would pick something else, it has a higher revving powerband that likely the Hi-Po heads, in whatever casting aren't going to be able to keep up with.
