I have made the header chart... what is the next chart you guys think I should make ? Open to suggestions. Not everything lends itself to a chart but the headers definitely do and Dodgestang has the wheels covered.
All of the Ford 5-speed manuals and 4-speed autos use almost exactly the same OD ratio as well as the 1:1 in the gear right before OD. With that in mind I made a small chart to calculate approximate RPM ranges for cruising at 60mph here...iskwezm said:how about a trans,rear gear,tire size = RPM chart????
66moneypit said:just go to www.stanginfo.com and click on the header link. By the way...based on your name do you work at Langley ? I worked there while I was in graduate school at ODU.
