header collector gaskets... help!
Just purchased seal-4-good aluminum collector gaskets to "solve" my exhaust leak, didnt work ... what else should i try to get rid of my pesky exhaust leak?? Also what is a good brand of header gaskets and bolts to put on factory 302 heads...
I just run a high quality set of fel-pro gaskets. The trick is to buy stage 8 header bolts which have a locking mechanism on them so the bolts do not loosen. That way your header gasket should never leak.
What kind of headers are you using? If you have factory style shorty headers, there is no gasket between the header and the h-pipe.
86bluecobra had good advice for the head-to-header gaskets.
Jeff
