very easy, dont even have to unbolt from the bottom (h pipe.collector)
the passenger side just looks hard, it just takes a little patience to tighten, the last nut on that side is a little trcky, just angle it good with an offset wrench, it's what i did
.... if they are the stock gaskets, you may want to remove the entire header(s) to scrape off the old gasket
