header question
  • Thread starter Thread starter Stangtamer
  • Start date Start date Sep 15, 2005
Stangtamer
62
  • Sep 15, 2005
hey everyone...im running mac 1 5/8 inch long tubes...the steering column goes thru it and it hits on the headers and i can feel it in my steering wheel...is there any long tubes out there that will not hit on the steering column?
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Sep 15, 2005
  • Sep 15, 2005
That's a new one for me...i'm using the same headers and mine are fine..? Is it just a little rub or a ton? Maybe just put a slight dint into the primary to help clear it?
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Sep 15, 2005
  • Sep 15, 2005
I think a flaming river steering shaft may work, i'd look into that, instead of new headers.
stang22
1,318
Washington, D.C.
Sep 16, 2005
  • Sep 16, 2005
It could be bad motor mounts as well. The flaming river shaft is a great option as well.
Tim
89notchfox
30
douglasville ga
Sep 16, 2005
  • Sep 16, 2005
i just installed a set of bbk long tubes and i had the same problem, i had to put a small dent in the #7 primary for the clearance i needed.
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
1965 mustang 351 850 hp+ primary tubes 1 7/8 or larger and a 3 inch or larger collectors?
  • 427nostang
  • Jun 4, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 7, 2026
DadLife0724
Suspension 87 steering wheel slightly wobbles after new Rag joint install
  • R82148V
  • Jun 16, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
R82148V
