Header Shrouding On 351W
  • Thread starter Thread starter danny clemens
  • Start date Start date Feb 7, 2011
D
danny clemens
728
  • Feb 7, 2011
I'm putting a 351W block in my 66 FB. I bought the Hedman engine swap headers mainly because I didn't want to put out the cash for a set of Hookers or JBAs.
I have a set of AFR 185 heads and upon measuring the exhaust port I found that it is about 5/32nds wider than my header opening. I have plenty of area on the top and bottom so it is the sides that are the problem. The header is going to overlap the exhaust port a little over a 1/16 of an inch on each side. I'm going to grind the edge of the header some (can't do much without making a hole in the 18 gauge steel) where the corner meets the head to make the exhaust transition as smooth as possible.
Is this a problem with headers on aftermarket heads because there isn't much space in between where the bolt attaches to the head and the header tube? There just isn't much room to spread the header tube out.
The car is going to be mostly a weekend cruiser and not really needing max performance but I'd still like to know is this going to cause some really bad turbulence in the exhaust port?
2+2GT
3,333
10
79
Southeastern Pennsylvania
Feb 7, 2011
  • Feb 7, 2011
The header should be 1/16" larger than the head, to avoid the exhaust gasses hitting a "step" from slight misalignment during assembly.
BuckeyeDemon
130
9
Cincinnati, OH
Feb 7, 2011
  • Feb 7, 2011
yes it's a problem with heads. i have stepped headers because i have the standard flange. however my headers are squared at the flange and just slightly larger than the port.
they make adapter plates that allow you to mate headers with the wider bolt pattern to a head with the standard pattern.
D
danny clemens
728
  • Feb 8, 2011
I don't know what the negative impact of these headers will be but whatever it is I'm stuck with it at least for awhile. If I'm not satisfied with the performance then I might check into the JBA or Hooker headers later on. There just aren't too many engine swap choices out there for headers on my car.
A
AlleyCat66
9
The OC, CA
Feb 8, 2011
  • Feb 8, 2011
That's why I made my own. That being said, I'll never do it again. It was a friggin nightmare. For me, maximizing performance was the priority so 1 5/8" or smaller primaries was out of the question. But that meant shock tower mangling and difficult-to-reverse modifications. If you're concerned with original appearance, or maintaining your sanity, take it from someone who did it (poorly).
As far as power goes, your situation isn't optimum but likely won't affect torque too much. And if it's mainly a streeter, torque is what's important. If you were building an 8000rpm screamer where port velocities were much higher, that'd be a different story.
69gmachine
576
Southern Maryland
Feb 9, 2011
  • Feb 9, 2011
Blend the flange as much as you can without risking breaking through a tube, and don't worry about it. You'll have plenty of power from your Windsor.
D
danny clemens
728
  • Feb 9, 2011
This isn't going to be a screamer and is being built with the main priority being torque which I think I'll have plenty of. The headers could have been widened a little bit at the factory to take care of the problem but I guess production numbers is key on a cheap part.
I think I'll grind the flange at an angle to neck it down to the secondaries and if I get the metal too thin I can always mig it back up on the outside.
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
D
Foxbody Misfire 5.0 Swap
  • DPORTER0729
  • May 2, 2025
Fox 5.0 Mustang Tech Jul 13, 2025
90sickfox
