header studs?
  • Thread starter Thread starter ryan218
  • Start date Start date Nov 23, 2007
ryan218
In just 10 years, I'll be old enough to drive!!!!
Dec 28, 2005
columbus ohio
Nov 23, 2007
  • Nov 23, 2007
i have a little bit of a deli ma...went and got tail pipes put on today...drove the car home..(80 mile drive) and as i was entering Hilliard it started whistling at the passengers side collector.. its lose again and the stud snapped before so i just use d nut and bolt to pull them together hence the first reason it leaked...so can i put in new header studs without removing the header? i have big hands so its hard enough to get my hands up there as it is....would it be easier to just remove the header?
this is for the passenger side...the stud closest to the block snapped.... by the starter
stykthyn
5,232
2,652
223
gainesville
Nov 23, 2007
  • Nov 23, 2007
try putting tech questions in tech. You would get a lot more responses
ryan218
Dec 28, 2005
columbus ohio
Nov 23, 2007
  • Nov 23, 2007
i dont really think of this as tech? but ok.
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Nov 23, 2007
  • Nov 23, 2007
If the pipe is out of the way, there should be no problem getting the stud up there. You'll need either a stud puller/installer or a couple of nuts to thread onto it to drive it in though.
ryan218
Dec 28, 2005
columbus ohio
Nov 23, 2007
  • Nov 23, 2007
k...happen to know what size the studs are?
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Nov 23, 2007
  • Nov 23, 2007
7/16", if I remember correctly.
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
