  • 1994 - 1995 Specific Tech
header to boot arcing!
  • Thread starter Thread starter saleener94
  • Start date Start date Jan 8, 2008
saleener94
153
Compton,CA
Jan 8, 2008
  • Jan 8, 2008
How do you fix arcing from the passenger side header, next to the egr tube and the spark plug boot, not sure but i think itz cylinder #4? I could see and hear it in the dark. Is there an easy fix? I have msd wires and bbk ceramic shortys. And might this cause a loss of power and hesitation at WOT?
FSTNG
37
Tampa Bay, FL
Jan 8, 2008
  • Jan 8, 2008
Did you try replacing the spark plug? I've had a bad plug cause that before. Also, are you using dielectric grease on the plug connectors?
Oh and yes this would cause a loss of power. If it is arcing out you are most likely not firing on that cylinder.
saleener94
153
Compton,CA
Jan 8, 2008
  • Jan 8, 2008
actually im in the process of doing a complete tune-up. I haven't really tried anything. I was thinking that the headers were causing this and not the wires. I'm going to replace the wires with ford racing and hope for the best.
MysteryMachine
1,835
Parkesburg, PA
Jan 9, 2008
  • Jan 9, 2008
i have brand new plugs and wires on our Ranger and I noticed it doing this as well. Does not using grease make that much of a difference?
95CobraMike
1,046
Lima OH
Jan 9, 2008
  • Jan 9, 2008
id get new plugs and new wires..... to be sure to fix the problem. electricity flows through the path of least resistance..... it should be through the wire and through the plug... if its arcing to the header that means that is the path of least resistance meaning there is a problem with the plug or a crack or a hole in the wire boot.... check both
yes if the electricity is arcing to the header that means that cylinder is probably not firing = power loss
saleener94
153
Compton,CA
Jan 10, 2008
  • Jan 10, 2008
Do boot protector help any? I ask because no one mentioned them and I believe thats what they are for.
Zero_chance
1,244
Maricopa, AZ
Jan 10, 2008
  • Jan 10, 2008
Theres gotta be some major problem for the path of least resistance to be jumping an air gap to the header. This happened tome on my 88 because there was a tiny tear in the boot of my wire on the number 6 or 7 wire and it was arcing out to the oil dipstick tube which was loose and rubbing. Whats the gaap on the plug / condition of the wires?
L
93 2.3L 5 speed manual with los of power
  • leadfoot67217
  • Jan 27, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Jan 27, 2026
leadfoot67217
L
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
