Header tube size?
  • Thread starter Thread starter cetstang902003
  • Start date Start date Feb 7, 2006
C
cetstang902003
15
Las Cruces,NM
Feb 7, 2006
  • Feb 7, 2006
When should you move from 1 5/8 header tube size to 1 3/4? I know if you go to big with a mild motor you'll actually kill some power so if there is any rule of thumb for choosing between the two I'd greatly appreciate it. Thanks.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Feb 7, 2006
  • Feb 7, 2006
the 1 5/8's will probably be best for a mild engine. the smaller primary's will allow your motor to make more torque then the 1 and 3/4's. that being said if you plan on upgrading your setup in the future maybe the 1 3/4 would be better. after all the power/torque you lose you will never know about because you haven't swapped between the 2 parts. I have 1 5/8's on my 351w and i am told that my application would prefer 1 3/4's.
D
Deleted member 87397
Feb 7, 2006
  • Feb 7, 2006
I wouldn't use 1 3/4 unless I was running FI
M
matm347
2,056
  • Feb 7, 2006
I would say anything more than a typical H/C/I combo would see benifit by going to a larger primary.
C
cetstang902003
15
Las Cruces,NM
Feb 7, 2006
  • Feb 7, 2006
I am running fuel injection with a cobra intake, GT40X heads, and a B303 cam.( check sig ) Will 1 3/4 header tubes be to much for this set up?
M
matm347
2,056
  • Feb 7, 2006
A different intake, or intake work would make more of a difference. If you've already got 1-5/8s I would stick with those until you get stroked or blown.
I
IntenseBlue
946
  • Feb 7, 2006
Around 475 flywheel horsepower is when to go 1 3/4 on a street or street/strip car.
04sleeper
2,674
14
89
Dallas, TX
Feb 7, 2006
  • Feb 7, 2006
I would NOT go with 1 3/4" LT's.
That is too much for your combo.
C
cetstang902003
15
Las Cruces,NM
Feb 8, 2006
  • Feb 8, 2006
Thanks for the help guys.
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
