Headers for 66 Fastback
  • Thread starter Thread starter Dr M
  • Start date Start date Sep 28, 2018
D
Dr M
Sep 28, 2018
  • Sep 28, 2018
Does anybody know of a manufacturer who makes shorty headers that will actually fit in the engine bay of a 1966 289 Mustang without having to a) dent the shock towers, b) dent the header, c) lower the rack and pinion steering, d) remove the Z-bar (although I am going hydraulic)? Anybody?
65-Fstbk
316
26
49
Vancouver, B.C. Canada
Oct 16, 2018
  • Oct 16, 2018
I have Hedman shortys on mine. Clearances are on the tight side but they fit in ok. I did need to "massage" one of the tubes slightly on the pass side head to allow proper access to one of the head bolts. Other than that no issue. I'm running a cable clutch and the cable does run fairly close to the header at the throwout arm so I made a heat shield and attached it between using the oil pan bolts as the base for the heat shield.
Now...I have started and run the motor but not driven the car any distance so we'll see if anything comes up. Almost ready to drive now.
bottom end is from a 87 5.0HO - torn down, honed/re-assembled with new parts (changed to carbureted)
ProComp alum heads
Comp Cam 281HR
Weiand Stealth alum intake
Quickfuel carb
Trans is a T5 5 spd
Can send you a pic if you want.
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
L
For Sale 1966 GT Fastback
  • lwg8tr0514
  • Apr 29, 2025
  • Classic Mustangs For Sale
Classic Mustangs For Sale Apr 29, 2025
lwg8tr0514
L
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
