headers for stroker
  • Thread starter Thread starter Travis77
  • Start date Start date Jan 9, 2006
Travis77
153
Baytown, TX
Jan 9, 2006
  • Jan 9, 2006
Hopefully this subject is not redundant. Need long tubes for my 67 mustang. This is what I will be running. 418 windsor,around 460hp, richmond six speed, hyd.clutch, with brodix track1 heads, 3:55 posi 9 inch.
I am in the middle of trying to get the motor running on a stand while the body work is being done. I am at a stopping point until I get my headers.
I believe hookers would work, but I want to double check. Also, what size would you run. The heads are stage 3 ported and they flow 180 /260 @ 500 lift if that helps any. They are only 195cc. cam is 229 242 @.050 and 112 LS. I was thinking 1 3/4 with 3" primaries and 3" exhaust. Any input would be much appreciated.
rbohm
6,698
550
204
tucson,az
Jan 10, 2006
  • Jan 10, 2006
you hit the nail on the head with your header choice.
thehueypilot
1,084
Medina,Tennessee
Jan 10, 2006
  • Jan 10, 2006
try: http://cprparts.com/index.html the fit was very good, but a bit pricey.
Travis77
153
Baytown, TX
Jan 10, 2006
  • Jan 10, 2006
Thanks for the information guys. Those were the same headers that were for sale on this site. I probably should have jumped on them.
He thehueypilot, would you go 2.5 exhaust if you had to do it over again? This is going to be street driven mostly but will see the track some. With that, I could probably stand to lose a little low end torque. I am most likely going to have a hard time hooking up with what I have. Given my combo, what would be the ideal exhaust system. Any experience with borla exhaust? Thanks
0to100to0
100
  • Jan 10, 2006
i'm planning on a similar set up
i'm planning on a similar set up (around 550hp) and have chosen to go with a 3" exhaust and here's why:
http://www.flowmastermufflers.com/faq.html
http://www.magnaflow.com/05news/magazine/05sporttruck01.asp
matt
thehueypilot
1,084
Medina,Tennessee
Jan 11, 2006
  • Jan 11, 2006
If it is mostly street yes; but if its for a race car I would go with 3". When I installed the 2.5" tail pipes it was a very tight fit out the back for the 2.5". (over the axle) I have not seen a 3" installed but I would think it is very tight.
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
Intended Headers and Trans, questions about fitment
  • from6to8
  • Aug 6, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 6, 2025
from6to8
J
68 Mustang with Foxbody Engine Stalling Issues - MSPNP2
  • JayV68Stang
  • Mar 13, 2025
  • Digital Self-tuning Forum
Digital Self-tuning Forum Mar 13, 2025
JayV68Stang
J
