  • 2015 - 2023 (S550) Mustang -General/Talk
Headers please help.
  • Thread starter Thread starter gray owl
  • Start date Start date Feb 21, 2026
G
gray owl
43
10
18
Alberta Canada
Feb 21, 2026
  • Feb 21, 2026
I really hope to get some advice. Is the HP gain from headers worth while. Seems to be a big job and the headers are expensive .
So is the HP gain significant enough to justify the cost snd performance gains.
Admin Dude
Jan 4, 1985
43,403
21,612
234
Box behind Walmart
Feb 23, 2026
  • Feb 23, 2026
Typical results from enthusiasts & dyno tests show:
Factory manifolds → restrict flow by design
Long-tube headers → best gains (~20–30 hp & 20–30 lb-ft) when combined with a cat-back/exhaust
Shorty headers → moderate gains (~10–15 hp & ~10–15 lb-ft) and easier install/less cost
Important! - Gains vary based on tune, supporting mods, and exhaust…
Without a tune: you’ll see smaller gains — often just a few hp, because the PCM doesn’t adjust timing/fuel for the new airflow.
With a tune: gains are much more significant and reliable.
So if you’re not tuning, headers alone can feel underwhelming. With a tune, they come alive.
Reactions: DadLife0724 and gray owl
C
ctandc
5 Year Member
Oct 28, 2017
80
71
28
Feb 23, 2026
  • Feb 23, 2026
Long tubes on a S550 Coyote and no tune is a big no go. You'll lose power until you tune it. - ECU can't adjust.
Reactions: gray owl
I Bleed Ford Blue
5 Year Member
Feb 13, 2017
416
122
73
North Olmsted OH
Feb 24, 2026
  • Feb 24, 2026
That's not true. On my old 17 I was 370 whp stock and 385 after the header install, no tune. Then after the ford racing stage 2 power pack and a custom tune I got 425 whp on 93
C
ctandc
5 Year Member
Oct 28, 2017
80
71
28
Feb 24, 2026
  • Feb 24, 2026
Long tubes? I've installed long tubes on 4 or 5 S550 Coyotes, none of them saw much difference until tuned and most ran badly at part throttle. And you installed the Power Pack 2 and custom tuned it? Wasn't PP2 a Throttle body, intake and a tune?
Just going by what I experienced.
Reactions: gray owl and DadLife0724
I Bleed Ford Blue
5 Year Member
Feb 13, 2017
416
122
73
North Olmsted OH
Feb 26, 2026
  • Feb 26, 2026
Maybe the 17 was a unicorn, IDK. Yes the PP2 was a TB, intake and tune. I was hoping the PP2 install would clear the CEL from the headers but it didn't so I had a local shop custom tune it to clear the CEL. I just had him clear the code so it will pass emissions, the tune was basically the ford performance tune modified for the header install. BTW the proprietary ford racing tune can be modified, but the only tuning device that will work is HP tuners.
Reactions: gray owl
C
ctandc
5 Year Member
Oct 28, 2017
80
71
28
Feb 27, 2026
  • Feb 27, 2026
I installed the PP package on my '19 GT when I had it. I didn't have headers on the car, no major mods, I just wanted to bump in low end and it did that at least.
G
S550 Headers
  • gray owl
  • Feb 1, 2026
2015 - 2023 (S550) Mustang -General/Talk Feb 1, 2026
gray owl
G
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
4K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
R
bbk shorty header to mid pipe gasket
  • randyyy
  • Sep 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2025
randyyy
R
