  • 1994 - 1995 Specific Tech
HEADERS UGGGH!!!!
  • Thread starter Thread starter Adam95GT
  • Start date Start date Dec 18, 2006
Adam95GT
2,564
Burlington, NJ
Dec 18, 2006
  • Dec 18, 2006
How do you guys put in the bolt on the front most driver side... behind the PS pump... i cant do it.... i just cant.... HEADERS FTL.... and i cant get the rear most on the pass side in either.... i went and bolt new header bolts that use an allen tool or 7/16'' and the allen stripped right out of the back most one... i cant get a wrench on it or anything... and i cant get the front most driver side started... so many problems today... H pipe wouldnt come off broke off the studs and they got stuck on the h pipe so i had to remove it and cut it off..... just a complete pain....
Adam95GT
2,564
Burlington, NJ
Dec 18, 2006
  • Dec 18, 2006
**** 2x posted
95cobraguy
637
11
Concord, NC by way of LI, NY
Dec 18, 2006
  • Dec 18, 2006
for the drivers side front u need a 7/16 universal, 1/4 drive with a few different extensions. i remember that bolt when i still had the p/s and a/c, it is a nightmare. since i deleted the a/c and p/s i can get to that bolt with my eyes closed. i always drill the end bolt holes a little bigger, elongating them. this way u have a little more side to side with the header and its easier to get the bolts started.
Killercanary
The car that set the bar.
Altoona, PA
Dec 18, 2006
  • Dec 18, 2006
If I remember correctly you bought used headers without a single flange that connects all the primaries together. if i am correct, then your problem is warpage. When headers with individual flanges (one per primary tube) are installed and heat cycled and then removed they are a bastard to get back on. You will need to have a friend pry that primary tube in whichever direction it needs to go while you try and get the bolt in. This is why you will see myself and others always post to get headers with a single flange that connects all of the primaries as they are less susceptible to this.
mootang
907
texas
Dec 18, 2006
  • Dec 18, 2006
yep, my old style bbk shorties without the one peice flange took me 8 hours to reinstall one day because they warped, i ended up prying them into position to get the bolts in. they were warped a good 1/4 to 1/2 inch though. if yours are warped do the hardest bolts first and then you can pry the other ones into possition to get the easy bolts in. good luck.
91LX_5L
1,943
British Columbia
Dec 18, 2006
  • Dec 18, 2006
I got my self the 10 point bolts they are easier but the one wrench, my favorite wrench is my 3/8 wrench with the flexible closed end (moves back and forth) with the ratchet action, its just slightly bulkier then most wrenches, nice and short and it works perfect for header bolts, I have changed my gaskets 3 times and 2 sets of headers and I love that wrench every time I use it...took me like 45 min to install headers vs 3+ hours without it the 1st time.
Adam95GT
2,564
Burlington, NJ
Dec 19, 2006
  • Dec 19, 2006
the problem is no longer the warpage... i got all of them to line up.... the problem is i cant reach the 2 bolts i mentioned with any took to tighten them...
Adam95GT
2,564
Burlington, NJ
Dec 19, 2006
  • Dec 19, 2006
Still having problems with the front driverside bolt... wont go in... i can get it in but i cant get a socket on it or wrench to start threading it strait.... ugghhh... the car is down and running i dont wanna drive it because i dont want to blow the gasket....
Therian
The Highlander
Waterloo, Ontario
Dec 19, 2006
  • Dec 19, 2006
They can be tricky. I think I remember that bolt. it was a PITA. You won't be getting a socket on it (or atleast I couldn't) so I would focus on wrenching. It's slow as hell...but you should be able to do quarter turns, even in that cramped location.
Just be patient...it will go in. You may need a smaller wrench (handle)
Also, I had to bring this up now...but what gaskets did you use?
G
ghetto5oh
70
so cal
Dec 19, 2006
#10
  • Dec 19, 2006
  • #10
i got an old wrench and just cut it in half to have a shorter hadle that way it should fit in that tight space, then just turn it slowly
Stanger007
2,015
Baton Rouge, LA
Dec 19, 2006
#11
  • Dec 19, 2006
  • #11
+1, I did the same... cut the open end off of a 7/16 wrench and used that to tighten the bolt.
Have used that same wrench a few times to take the headers on and off.
Wes
Adam95GT
2,564
Burlington, NJ
Dec 20, 2006
#12
  • Dec 20, 2006
  • #12
the problem is i cant get the bolt started... so i cant wrench it in... if i could get it started strait it would be no problem a 1/4 drive and socket with a univerisal will reach it with a 6'' extention
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Dec 20, 2006
#13
  • Dec 20, 2006
  • #13
maybe you need to reem out that bolt hole in the header flange
Adam95GT
2,564
Burlington, NJ
Dec 20, 2006
#14
  • Dec 20, 2006
  • #14
think im about to just take off the PS pump and save me alot of head ache....
urban96
3,464
Syracuse, NY
Dec 20, 2006
#15
  • Dec 20, 2006
  • #15
its probably easiest to remove the whole bracket, only 3 bolts. one of them is right behind the PS pulley tho. but if you have a thin 1/2" wrench you should be able to fit it in there to get to the bolt
BlackVert
5,589
9
98
Bethesda, MD
Dec 20, 2006
#16
  • Dec 20, 2006
  • #16
but then it's next to impossible hard to get the ps bracket off without taking the pulley off. i couldn't get a wrench in there
how about using a stud for that spot?
Therian
The Highlander
Waterloo, Ontario
Dec 20, 2006
#17
  • Dec 20, 2006
  • #17
have you tightened any of the other bolts on that side? I'd be taking the other three out, and focusing on that first one
Adam95GT
2,564
Burlington, NJ
Dec 20, 2006
#18
  • Dec 20, 2006
  • #18
I beat the bolt.... 11mm U jointed socket with a 6'' 1/4'' socket extention.... worked out well... had to put alot of pressure on it but i got it to go! and strait at that... there is a small exhaust leak still i think... it could just be the pipe to my smog thats not connected to my cats... or it could be the sound of a better breathing motor... ill check it out tomorrow i guess... there is a noticable difference with the headers though... i didnt think there would be...
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
R
bbk shorty header to mid pipe gasket
  • randyyy
  • Sep 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2025
randyyy
R
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
R
For Sale 2008 Mustang Bullitt for sale Richmond Hill, ON, Canada L4C 0S3
  • ROHDRNNR
  • Jun 10, 2026
  • S197 Mustangs For Sale (2005-14)
S197 Mustangs For Sale (2005-14) Jun 10, 2026
ROHDRNNR
R
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
