  • SN95 4.6L Mustang Tech
Headers
  • Thread starter Thread starter CENTENNIALSTANG
  • Start date Start date Oct 22, 2005
C
CENTENNIALSTANG
Houston
Oct 22, 2005
  • Oct 22, 2005
Do headers help us 2v much. Does anyone run long tubes or shorties.
W
WOT
2,817
Regina, Canada
Oct 22, 2005
  • Oct 22, 2005
NA go LT. Blown doesn't really matter much.
helty
some Ukrainian's enjoying a handjob via my credit
Mar 30, 2005
1,461
Baltimore, MD
Oct 22, 2005
  • Oct 22, 2005
longtubes do help, but i'd upgrade the rest of your exhaust and intake parts, then get a new clutch before LT's. (most LT's require you to remove them in order to change the clutch on our cars, and LT install is a pita on 2V's) but you will get a power increase across the board. shorties dont help near as much as LT's because the factory manifolds arent too bad. they arent great, but there have been worse.
'03GTinFLA
486
St. Petersburg, FL
Oct 22, 2005
  • Oct 22, 2005
LT's definate SOTP gains. No dyno to back it up, but others have dyno's that show decent gains of 11hp and up. It's gonnna get expensive. If your thinking of doing the rest of the exhust first remember that you'll need a shorty x/h mid pipe. I picked up a shorty prochamber off the trader section here for cheap. The cat back can be done first, but if your going LT's, wait to change mid pipe instead of buying it twice. If your gonna do it yourself that will save some money, but if not, call around and get some quotes as to how much for install and ask if they have done LT's on a stang before. The place i went charged me $300, but that was because they thought it would be like putting shorties in. They never did LT's before. I had to take it back 2x's to fix a leak. Get it done right the first time. Same thing with headers, don't cheap out.
Good luck.
crew_dawg16
445
DeKalb, IL
Oct 22, 2005
  • Oct 22, 2005
If you are going to go through the trouble, make sure you know what you are getting yourself into with LTs. I have had to remove one of mine to change the clutch already, it turns a 3 hour job into a damn near 13 hour job. They are great as far as power goes, you can tell a huge difference in the torque curve and pull up top. I prepare for an entire weekend for the install if not more.
C
Chopper1
91
Wv
Oct 22, 2005
  • Oct 22, 2005
I have a full Bassani exhaust w/cats that use mid-length headers.Hooker,Kooks and Bassani are the only ones that will allow transmission work with the headers in place(I believe???)Bassani headers also do not decrease ground clearance and are 50 state legal.According to MM&FF you get 17.3 HP and 17.4 ft/lbs of torque on a stock GT with a full Bassani exhaust w/cats.Shorties are no easier to install than long tubes and if you know what you're doing will still take several hours.I gave up and had the car towed to the dealer and paid $620 for them to do the job.Labor time was six hours for two techs (there were actually four) and they had all the right tools.Lift,engine support,and previous experience.
TweekedGT
1,274
Alberta
Oct 22, 2005
  • Oct 22, 2005
You can really feel longtubes. It does give some good grunt but pita to install.
White Stang
467
Ft Lauderdale
Oct 22, 2005
  • Oct 22, 2005
I am happy with SLP LT and full exhaust LT install is a PITA though unless you have a lift.
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Oct 22, 2005
  • Oct 22, 2005
i have yet to dyno it. But it does feels like once past 3500rpm, starts to pull much better then when i had iron anchor
csledd
Official Ovary Punching Member
1,115
Paducah, KY
Oct 22, 2005
#10
  • Oct 22, 2005
  • #10
Lts is the way to go if you're going to do it. Install can be a PITA very easy. If you do it DROP THE K-MEMBER.. unless you have access to a lift.
I lost some low end power after installing the full exhaust but back when it was cold when they were first installed the car would lose traction at 4k and try to get sideways.. it was pretty cool. After having the car dyno tuned I gained back a lot of the power I lost down low.
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
W
Dipstick
  • wccurtis1963
  • Jun 13, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
Willybill32
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
1965 mustang 351 850 hp+ primary tubes 1 7/8 or larger and a 3 inch or larger collectors?
  • 427nostang
  • Jun 4, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 7, 2026
DadLife0724
G
S550 Headers
  • gray owl
  • Feb 1, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Feb 1, 2026
gray owl
G
