headers
does it hurt to run the car with strait headers until i can get my exust re welded i have flow masters on it now with the h pipe can i reuse this
It is possible to hurt your engine by driving it open header. It isn't likely, but it is possible for the engine to suck up cold air back through the headers and burn a valve while decelerating.
The most affordable option is to buy a set of longtube headers in combination with a matching intermediary (h-pipe). You can have an exhaust shop cut down the factory h-pipe, and make it fit, but it will end up costing more than just buying an aftermarket unit. the factory H-pipe is also restrictive. The factory exhaust is 2 1/4", while all the aftermarket pipes are 2 1/2" If you buy a set of longtubes with the matching H-pipe, there won't be any welding required, it's all bolt in.
Here are some things you need to know with longtubes.
1. Installing the headers is not hard, but is time consuming. You will have elevate your car quite a bit, so that you can get a good angle to install the left side header from the bottom. You will have to unbolt each motor mount individually, and jack up the engine to get enough clearance on each side to get the header in. This isn't as hard as it seems. You will also need to disconnect the steering shaft to get the driver's side header in. Also not that hard, it's only one bolt.
2. The position of your oxygen sensors will change. You will either have to extend the harnesses on your Oxygen sensors, or buy new Oxygen sensors. If you decide that it is a good time to change your Oxygen sensors anyway, you need to go to the parts store and ask them for a pair of oxygen sensors for a 92' Ford Ranger V6 (3.0 or 4.0 doesn't matter, they are both the same). This will give you the oxygen sensors with the correct length pigtail.
3. Most people agree that the BBK headers are the best fitting. If you get the BBK headers, you will find that the AC liquid line gets pinched between the passenger side header and the inner fender. The heat from the header WILL melt your AC line, and cause all your gas to leak out. This is an easy fix. All you have to do is drill a hole in the strut tower a little higher up, and remount the line about 2 inches higher. It flexes up easily with your hands. If you don't do this when you do the headers, you will most likely burn that line out immediately, and have to replace it.
4. The BBK headers have a bung to reattach the line to your EGR on the passenger side. However, the tube itself has to be "motivated" to fit. BBK sells a replacement tube that fits, but you can get the factory one to work by bending it.
5. I just put a BBK longtube in a customer car a few weeks ago. The BBK X-pipe was about an inch to narrow, and I had to bend it out a little bit to fit. I used an engine hoist with some ratchet straps, but I have heard of people putting a floor jack in between the two pipes and bending them out. If you intend to do a lot of modification to your car, and you buy a lot of aftermarket parts, get used to these inconsistencies.
6. The factory header bolts are big and nasty, and tend to have the unattractive, but helpful characteristic of rusting themselves into place. You will not be able to reuse the factory header bolts because the primaries on longtubes are bigger. However, if you use the provided bolts with the headers, they tend to have the crappy characteristic of backing out, requiring constant tightening. It's not a bad idea to get a set of locking header bolts with the headers. The most common brand it "Stage 8" and Summit racing sells them.
7. The header gaskets provided with the headers are paper, and suck balls. It's also a good idea to cough up the $8 for a set of Fel-pro gaskets from the parts store.
8. If you have never done this job before, give yourself a full 2 days to get it done. I have put longtubes in a Mustang at least 20 times, and it still takes me almost a full day to do it by myself.
Longtubes require quite a bit of work, but it's totally worth it. It makes a big difference in performance.
Kurt
please
94 gt here ive priced headers but the labor everyone wants to install them is insane i want a good pair that is fairly cheap any recomendations i also have to go thru emmisions testing here ware i live and ive been told that if u get to crazy with the motor like a cam it will not pass emissions does any body have this same problem please let me know and ive put a pair of headers on an old small block chevy it was easy but the mustang is very tight under the hood please give me any tips thanks i got a quote for $960.00 for the labor tp put on the headers thats with me supllying the part
wow,if your gonna pay that,you can fly me up there and i'll do it for half the amount:)
joking.
BBK unequal length fit well.new they run $200.
i got mine used in great shape for $100(thanks Adam).
they will pass CA smog,so where your at should be no problem.
its not bad at all installing.
just take your time,you can knock it out in a few hours.
if you think you can,do it yourself.
with the money you would have payed for the install,get some stage 8 locking header bolts (reusing the stock bolts are a pain in the a**),felpro gaskets(heard the BBK gaskets were junk),and an h or x pipe
i removed the intake tube to install the passanger header from the top.
on the driver side,i disconnected the steering shaft and installed the header from the bottom.
BBK's will most likely be the cheapest way to go. They are priced well, and have a flange on them to keep the primaries aligned during install. This makes life MUCH easier :nice:
As long as the headers have the provision for the EGR on the passenger header, you will pass emission testing.
If you are installing shorties, like davis3 said, just take your time and you should have no problem. If bought new, they will come with instructions for install.
What else is done to the car?
If you are pretty much stock, swapping the headers is not what I would do. You already have headers on your GT, and they are decent enough to support the Cobra 5.0L.
i am fixing to buy headers for my 94 gt i am going to get shortys so the will bolt up to my exhaust i just would like to know are the chrome headers good ive heard they want rust if u clean them if this is tru i would rather save my money then buy ceramic thanks
Posted via Mobile Device
i'm not trying to be rude,so please don't misunderstand me.
but,
#1.you could have brought this up in your other thread about headers.it helps to keep the forum from getting all cluttered up.
#2.put a brief discription in the thread title,instead of "please".
#3.PUNCTUATION.
a comma,or period,or question mark can completly change the meaning of a sentence.it can only help us,help you.
now on to your question.
bbk chrome headers will discolor after a few heat cycles,will not affect performance,just wont look very pretty.
the ceramic's will look pretty,and control underhood temps better.
