Ok, here's a problem I've been fighting for a bit. When I first got my car running, the center headlights (high-beams) were not wired, and everything worked great. A month or two later, I finally got around to wiring them in, just as the were on real '67 Shelby's, according to my assembly manual that I got from Branda's. That's when things went bad. Now everything's fine as long as the lights are on low beam, but when I put the high beams on, although everything works, after about 2 or 3 minutes, the lights (including the dash lights) blink once or twice, then go out completely. Once I hit the dimmer switch to bring the low beams on, it all goes back to normal. I've checked the wiring, and an electrician freind says it sounds like a weak relay, but try as I might, I cannot find any sort of a relay either in the wiring diagram in my Ford shop manual, or on the car. Any one got any ideas at all? Thanks!
