Headlight Lens
  • Thread starter Thread starter Lynx331
  • Start date Start date Sep 26, 2004
L
Lynx331
308
Chicago IL
Sep 26, 2004
  • Sep 26, 2004
I want to take off my clear headlight lens so i can clean the insides and then seal them up completely with silicone. How do i get the clear front lens off of the housing? Thnx
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Sep 26, 2004
  • Sep 26, 2004
I would just buy some OEM lens and housings...they are $30 bucks a piece from 50resto.com and made my car look a lot better on the front end...and usually the "uncleaniness" of the bulbs (yellow) are on the outside...and it takes a lot of elbow grease to get them to look as good as new...
trbkrb
1,976
Houston, TX
Sep 27, 2004
  • Sep 27, 2004
You can take them apart, but you have to be careful. The two parts are glued together, but you can get a small screwdriver in between the two parts and maybe pry them apart. But the parts might break. I would only do it if it is actually leaking. I had to do one of mine since it was leaking and the metal reflector had come loose and was rattling around in the light. I glued it back together with some clear silicon sealant.
Good luck!
FrdMustangCpe
493
Sin City, NV
Sep 27, 2004
  • Sep 27, 2004
i assume they are leaking otherwise nothing could get in there and dirty them up. I would atleast give it a shot on taking them apart before dropping the money for the new ones. if the outside is oxidized (sp) then ive heard metal polish will take that out.
good luck
Electrical Headlight Harness Route
  • dan50
  • May 3, 2026
Fox 5.0 Mustang Tech May 3, 2026
dan50
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
Drivetrain Tail Shaft bore odd shape
  • R82148V
  • Jun 12, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
Mustang5L5
Paint and Body Cowl Pan
  • jeremyzcook82
  • Sep 13, 2026
Fox 5.0 Mustang Tech Oct 3, 2026
Rcdgl
R
