  • SN95 4.6L Mustang Tech
Headlight out warning and HID's
  • Thread starter Thread starter Maxpowers
  • Start date Start date Jul 16, 2011
Maxpowers
859
Pittsburgh, Pa
Jul 16, 2011
  • Jul 16, 2011
So I installed a set of HID's on my car. They plugged into the driver's side socket and the passenger side stayed empty.
The lights work, however, the high beam light came on in the dash very dim and did not allow the fog lights to come on. When I put the high beams on, the headlights do appear to get brighter or change pattern at least and the high beam indicator light becomes the correct brightness.
I also attempted to install a set of warning cancelers with no effect.
Anyone run into this before? I think I remember someone writing a review on American Muscle's kit about having to pull a relay from under the dash and cut a prong off, but I can't find it now.
Edit: Forgot to add. I put a stock bulb into the passenger side socket and the fog lights came on and the light went out on the dash.
I
ItsStock02
492
Westland, MI
Jul 16, 2011
  • Jul 16, 2011
I run my hids with no relay harness and have zero problems. Get rid of the harness and you will be better off.
Maxpowers
859
Pittsburgh, Pa
Jul 16, 2011
  • Jul 16, 2011
I've tried using the warning cancels and not. Doesn't make a difference either way.
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
U.S.A, U.S.A., U.S.A.!
Jul 17, 2011
  • Jul 17, 2011
I'm sorry to hear you are still having problems with your HID's, it sounds like your HIDs harnesses are requiring to low of voltage which will give you electrical problems, e.g. like using LED's in place of your tail lights or side markers, in which turned on my dash board lights w/o my head light switch being ingauged.
Seems like you need to find a another HID company, its not your car, but your harnesses.
Maxpowers
859
Pittsburgh, Pa
Jul 18, 2011
  • Jul 18, 2011
I tried to sell them, but felt bad when the new owner said he couldn't get them to work either. I figured I'd give it another shot in my car.
I found a few threads on line about people with similar problems. Each one is having issues with the dual beam.
Anyone who is more educated in how HID's work, read this thread and let me know what you think. I already registered and sent a PM to the user that seems to know the secret answer:
http://www.lonestarstangs.com/forum/hid-problem-55656.html
Maxpowers
859
Pittsburgh, Pa
Sep 3, 2011
  • Sep 3, 2011
For anyone searching in the future:
Apparently the Mustang headlight socket is set up different than most other 9007 headlights. Not sure why.
I was able to get them to work properly by changing the positioning of the three wires that plug into the stock harness. They all have random colors, so you can't really tell which is power, negative or ground. I got it right on the first shot by switching the center wire with the driver side wire.
I busted the cheap adapter that plugs into the stock socket, but found one on ebay for a few bucks.
P
paradigm
50
  • Sep 5, 2011
by driver side wire, is it driver side when the socket has the flat edge up or down?
Maxpowers
859
Pittsburgh, Pa
Sep 6, 2011
  • Sep 6, 2011
Driver side when it's plugged into the headlight. If I had to guess, I'd say the flat spot would be on the top.
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
N
1966 driver headlight dim
  • nsterns
  • May 4, 2025
Classic Mustang Specific Tech May 4, 2025
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
Resolved HELP! - 1992 5.0 Canadian with DRL - need electrical schematic drawing
  • 92StangGirl
  • Nov 28, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 7, 2024
92StangGirl
9
  • dan50
  • Jul 18, 2026
dan50
