  • 1994 - 1995 Specific Tech
Headlight problems
  • Thread starter Thread starter reject5.0
  • Start date Start date Sep 17, 2005
R
reject5.0
153
Round Rock, TX
Sep 17, 2005
  • Sep 17, 2005
I had a headlight go out. I pulled the bulb and it was bad. I bought 2 new ones and put em in...everything was great. A couple days later, the same headlight went out again. I pulled the bulb, and it looked OK. If you tapped on the headlight, it would work again though. I figured it was bad to so I replaced it again. Well, then the bulb on the other side went bad. I tapped on it and it worked again, but that was just a temporary fix. Its out again right now.
The thing is, the brights always work, its just the dims that are hit/miss. EVERYTIME i use the brights both light up. Its just the dims that are giving me problems.
Where should I start my search? Thanks guys.
tsoccer3299
255
Tacoma
Sep 17, 2005
  • Sep 17, 2005
mine would occasionally go dim on the drivers side and i just went to a junk yard and got the connector where the headlight plugs into and since has worked fine
R
reject5.0
153
Round Rock, TX
Sep 17, 2005
  • Sep 17, 2005
Ill check some things with a circuit tester and other stuff tomarrow if I can wake up in the morning.
Thanks for the input though.
Blackened302
1,439
South TX
Sep 18, 2005
  • Sep 18, 2005
yeah, might wanna check the harness, and the ground.
M
Need help!
  • Masonevans726
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 17, 2025
Masonevans726
M
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
