I had a headlight go out. I pulled the bulb and it was bad. I bought 2 new ones and put em in...everything was great. A couple days later, the same headlight went out again. I pulled the bulb, and it looked OK. If you tapped on the headlight, it would work again though. I figured it was bad to so I replaced it again. Well, then the bulb on the other side went bad. I tapped on it and it worked again, but that was just a temporary fix. Its out again right now.
The thing is, the brights always work, its just the dims that are hit/miss. EVERYTIME i use the brights both light up. Its just the dims that are giving me problems.
Where should I start my search? Thanks guys.
