Headlight Sealant/Adhesive
Blackrosepet
55
First off, I have aftermarket Cobra headlights. Walking out to the car today, I noticed that my headlight lens was just basically hanging there. I could take a hold of it and pull it from the housing. What should I use to cement these two pieces back together? Will silicone adhere them as well as seal?
1TallMF said:
I would probably use windshield adhesive (if you can get it clear). That's tough stuff. A clear silicone might also do the job, but won't be nearly as strong. Don't use epoxy.
Why not epoxy? I had the same problem with my headlights, and some epoxy did the job really well.
Yeah, Sikaflex is what you want to use. Flexible and extremely good adhesion. Comes in 5 colors i beleive, and be careful when applying, b/c it's a PITA to get off if you make a mess.
Scott
I'm not 100% sure why. I recall using 5-minute epoxy on plastic before and it had melted part of the plastic away. I could be mistaking it for something else though, memory's not as sharp as it once was.... or wait now... it never really was that sharp to start with :shrug:
It may be a better idea to use a flexible adhesive to do this, and epoxy tends to harden like a rock, and become ugly and yellow with time. Its good for a quick fix though.
