Headlight Switch Dead again, Please help
  • Thread starter Thread starter dragstang88
  • Start date Start date Jan 2, 2004
D
dragstang88
29
  • Jan 2, 2004
Ok, when i bought my 88 GT, the foglight switch was completely bypassed. (no wire going into the 2 pins on the back.) However, when you put the switch of the first position for parking lights and dash, etc, the foglights would come on automatically, and in the 2nd position the foglights would stay on with the headlights wether hi or low-beams. I actually like it this way, however in the past 3 weeks, i have killed 2 switches. now before i buy another i want to know what is causing me to go through these. i've had the car for almost 2 1/2 years, and this has only started happening recently. The Plug for the headlight part of the switch is burned/slightly melted right in the middle. Now i've done a search, but couldn't find anything with the fogs wired the way mine are. any ideas?? Thanks
Cliffs--keep eating headlight switches, did a search but no identical result. Please help.
D
dragstang88
29
  • Jan 2, 2004
and i forgot to mention, i recently added (a month and a half ago) a 3g alternator. figured that might contribute to it.
HISSIN50
34
129
Jan 2, 2004
  • Jan 2, 2004
sounds like some moron took the output line off the fog switch and connected it to the light switch (parking light) output. not bad in and of itself, but....
this is what i would bet the problem is. there could be other things, but this would be where i start.
you really need to put a relay on the headlights and fogs. i have one for all three. the stock switch was not designed to have the extra draw of fogs running through it, and it overloads. even headlights alone is marginal.
you could probably get away with a relay for the lows if you like the way the lights work in this configuration (and you dont run highs for very long at a time). if not or you want more info, post or pm.
good luck.
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
Resolved Ignition switch questionable
  • Dontknowchit
  • Mar 14, 2025
Fox 5.0 Mustang Tech Jun 18, 2025
General karthief
M
Electrical Headlight switch not working properly
  • MaxFerguson
  • May 26, 2024
Fox 5.0 Mustang Tech May 26, 2024
rednotch
