Headlights/Interior Lights Pulsing
  • Thread starter Thread starter 67_Vert
  • Start date Start date Apr 29, 2007
67_Vert
  • Apr 29, 2007
Greetings all!
I just picked up a 67 convertible, fully resto'd and really the only thing I can find wrong with it is that the headlights and interior lights pulse when you bring the RPMs up a little. Any ideas on what might cause this? Alternator?
Thanks in advance!
BTW, you can see pics here if you want:
http://picasaweb.google.com/bdillon08/Mustang
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Apr 29, 2007
  • Apr 29, 2007
Could be a couple of things. If you can check the voltage at the battery while it happens that would tell you if its the alternator. Just have a friend rev it for you. Also, it could be that the headlight switch itself is going bad and the vibration from the engine is causing it to short intermitently.
T
TOM B
20+ Year Stangneter
Nov 15, 2002
872
Harrisburg Pa
May 1, 2007
  • May 1, 2007
Most if not all older mustangs will do this because of the low 60 amp alternator and regulator, upgrade to a one wire 100 amp alternator and get rid of all your troubles.
T
tretz
62
stockton, ca
May 1, 2007
  • May 1, 2007
cured mine with a new light switch
65fastbackresto
1,229
AR
May 2, 2007
  • May 2, 2007
Mine does it too
I thought it was normal....
66HertzClone
428
Central New Jersey
May 2, 2007
  • May 2, 2007
Look for the ground strap between the rear of the right side cylinder head and the firewall. Often missing, this pesky little thing can cause the symptoms you describe, to make sure the strap will help, place a jumper cable between the block and a hefty bolt on the chassis. The original point type style voltage regulator can sometimes cause this, a new replacement using an electronic style is a good inexpensive improvement.
J
justford
66
Grayson KY
May 7, 2007
  • May 7, 2007
The electronic voltage regulator cured my problems with the lights.
67_Vert
  • May 11, 2007
Which one did you use?
My switch is also bad, the potentiometer doesn't seem to work. As I turn it to the right to dim the interior lights, the lights flicker on and off.
I will replace both, I just need a recommendation on which voltage regulator to use.
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
May 11, 2007
  • May 11, 2007
My car did the same thing. It was either the voltage regulator or the alternator, I replaced both and it fixed my problem. It had nothing to do with the alternator being too small....
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
What's it Worth? 2000 GT
  • Mustang5L5
  • May 8, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jun 13, 2026
KRUISR
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
Resolved Gauges and lights pulsing
  • sav22rem22
  • Sep 25, 2023
4K
Fox 5.0 Mustang Tech Oct 23, 2023
sav22rem22
97 Cobra Bank 2 Running Rich
  • 91LX302
  • May 29, 2023
  • SN95 4.6L Mustang Tech
2K
SN95 4.6L Mustang Tech Jun 1, 2023
91LX302
