Headlights shorting out
  • Thread starter Thread starter PonyNerd
  • Start date Start date Feb 20, 2008
P
PonyNerd
9
Lancaster, CA
Feb 20, 2008
  • Feb 20, 2008
It's amazing the number of quirks that surface when a car goes from a weekend toy to a daily driver. The leak in the tranny line has been fixed and a new tranny dipstick and tube should arrive soon.
Back in December or so I developed a random flicker in the headlights. I'd be driving and the lights would turn off for a second or two then come back on. It was very sporadic. The rest of the electrical system seems to be uneffected.
Last Wednesday it went from a random nuisance to a full out major problem. Tonight I fixed two problems that I thought were the cause. The first was exposed and corroded wires for the passenger headlight near the battery. I cut out about 3" of wire and spliced in some patches on 4 of the 5 wires. Next I temporarily fixed a loose wire on the driver-side turn signal. But no love - the lights still turn off randomly for 2 or 3 seconds or more (tail lights stay on).
The car is a salvage and I know that some of the wiring is actually missing (i.e. all the wiring for the courtesy lights, the wire for the oil pressure sensor) so I don't know what is wired right and what isn't.
So a couple of questions:
1) Any suggestions where to look next? Could it be the headlight switch itself?
2) Any recommendations for replacement wiring kits? Even though the entire car needs rewired, I'd probably just replace from the harness at the firewall to the lights for now.
3) When I pull the headlight switch to the first position the driving lights come on. At the second position headlights come on, but the driving lights turn off. Is this normal, part of the same problem, or a seperate problem?
I just need to make her a daily driver for a month or so until my '97 Steeda Cobra is back on her feet. Then she can go back to being a weekend driver and project car.
Thanks for your help!
suki243
662
Southern California
Feb 20, 2008
  • Feb 20, 2008
1.) it could be the headlight switch, do the lights in cabin itself like dash lights turn off as well? It could also be faulty grounds, check the grounds for the headlights. If a wire is corroded at one point it is most probably corroded all the way through, a 3" splice probably won't do much.
2.) If it's going to only be to the firewall and to the lights i'd just get 16 gauge wire and run it through, you're going to replace it anyway when you rewire. Same for the oil pressure, its easy to wire its a single wire that connects to the top of the sensor and then to the gauge.
As for replacement harness recommendations, i believe its either between Painless and EZ wiring.
Painless costs more but i hear its easier to install because its an exact or pretty close reproduction of the stock harness.
I used EZ wiring, i bought it for 120$ or something close to that, its a universal harness with 21 fuses, it uses mini fuses, the other fuses some can be hard to get ahold of I'm not 100% sure tho but that's what i've heard. If you do go with EZ wiring get the mini series not the regular ones, i heard the regular fuse one has a huge fuse box, mine on the other hand (the mini version) is a smaller than the stock mustang one. The tech support for EZ wiring is really helpful and quite a few ppl on the forum who have used either or. Also, EZ wiring makes you use the old connectors, for example the bunch of wires that come through the firewall, they come through a rubber plug called the master disconnect, there are two, that is a rare part, i couldn't find that anywhere, i was forced to use the old one, but i didn't use the ones that were badly corroded,
3.) i believe it is normal for that to happen, it happens on mine
What year is the car? 65, 66 have practically the same system not sure about 67+
http://midlife66.com/wiring/wiring.html
That is a great reference, it tells you where the grounds are and how the wires are run, specifically check out exterior lighting both the detail and the schematic.
Tim65GT
1,149
West Texas
Feb 20, 2008
  • Feb 20, 2008
The head light switch has a circuit breaker in it to protect the wiring to the headlights. Like everything, when it gets old they start getting quirky. Replace the switch. If you have Halogen replacement headlamps, do a search on Head Light relays. You might want to do this mod.
pabear89
2,126
High in the Hills of So Ca with the Voices in My H
Feb 20, 2008
  • Feb 20, 2008
Has the steering wheel been off or changed?
Lack of lube on the horn contacts under the wheel will cause this condition.
If so, use a small dab up lith grease on the underside of the wheel on the horn ring.
PB
BarnStang
1,260
Hagerstown, MD
Feb 20, 2008
  • Feb 20, 2008
Does it do it on high beam AND low beam? THe power for the headlights all run through the dimmer switch. Make sure you check that connection and the switch.
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Feb 20, 2008
  • Feb 20, 2008
Start with the headlight switch as it sounds like you are tripping the self-resetting breaker.
This happens all the time to people who have upgraded their headlights to halogens (or simple replaced them with off the shelf parts and un-knowingly upgraded to halogens in the process).
If the headlights are halogens, you'll want to install a headlight relay (do a search, there are a million threads).
Otherwise, you might want to change the switch just in case.
P
PonyNerd
9
Lancaster, CA
Feb 21, 2008
  • Feb 21, 2008
I want to thank everyone for your responses - they have been extremely helpful.
To answer some of the quesitons:
- '66 coupe, rebuilt 289, AT, Frankensteined from 2+ donors
- Halogen lights (found a website about the relays last weekend and bookmarked it for future reference - guess I'll be ordering parts tonight)
- Effects both hi and lo beam
- Does not effect interior lights
- Didn't know there was a circuit breaker in the head light switch, but the way it acts, it does seem like a circuit breaker tripping off and on
- Steering wheel was probably removed by the PO that pieced it together. I can tell you that the horn doesn't work and the turn signals don't turn off after making a turn
Better go order some parts for the relays. Thanks and I'll let you know if the relays do the trick.
H
Hawkk72
47
  • Feb 26, 2008
Had the same problem in my 72. Replaced the headlight switch and BINGO!
68stang351
850
9
39
Savoy TX
Feb 26, 2008
  • Feb 26, 2008
It seems like most of the time its the headlight switch. I've sold many headlight switches that cure the problem.
M
mo'factor
58
#10
  • Feb 26, 2008
  • #10
headlights
Here is what I did:
http://www.theclassiccougarnetwork.com/tccn2/index.html
M
mo'factor
58
#11
  • Feb 26, 2008
  • #11
The aforementioned link only takes you to their index. From there go to tech/How to, then restomod, and finally Halogen headlights.
Thanks
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Wednesday at 11:12 PM
SN95 4.6L Mustang Tech Thursday at 7:00 AM
DadLife0724
