Headlights wont go on now
i did the corral.net foglight switch fix and got everything to work besides the headlights when i pull the turn signal towards me the high beams work but when i push it forward for the high beams to stay on nothing comes on..... the only thing on is parking lights and foglights are on but no headlight (low beams)???? any help would be appreciated oh yea and the fog lights turn on when i put on the parking lamps so i know i did the fog light fix right and did everything it said to do in the article on corral.net
the only thing left i can think of is the turn signal went bad but not sure??????? thanks again
Check that the red/yellow wire from the headlight siwtch to the MF switch is intact. It can back out of either switch. If it looks ok, test I/O voltages at each switch.
The reason your FTP works is because it uses a different power source.
Good luck.
Did the switch totally crap itself, or did the wire just back out?
If you need a new switch, remember they were different for tilt and non-tilt cars.
Nice work!
the switch just crapped out when i pulled the 4 pin connector out of the mulitifunction switch the middle red/black wire was melted cimg0390yk1.th.webp so i replaced the plug and the multifunction switch and everything works i used a 1990 lx mulitifunction switch for my 93 gt
