Headlights
  • Thread starter Thread starter SteedaGT9150
  • Start date Start date Mar 31, 2005
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Mar 31, 2005
  • Mar 31, 2005
Im getting ready to order a set of new headlights from 50 resto. Are there any tricks to putting them on? thanks
1990Coupe
1,462
132
114
Toms River NJ
Mar 31, 2005
  • Mar 31, 2005
I ordered the same ones from 50resto,, not much of a trick to doing them. You need to take out your parking lights, thats the only way to get them out. Make sure you test fit the headlights too, when i put mine in, i just threw the left side in without test fitting . The light pointed like to the ground! Also i would park infront of a garage or get a piece of cardboard so when u turn them on, you can adjust the beam.. Its really easy tho no problem!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 31, 2005
  • Mar 31, 2005
If you bought Genuine Ford headlights, the adjustment will be easy. If you bought reproduction headlights, they will be very difficult to align properly. I bought reproduction units the first time, and my headlights could not be aligned: they would shine up in the trees and across the road. I even had all 3 screws set up as adjustment screws.
The set of headlights I now have say "Ford" on them and they seem to line up properly.
There are two sets of screws that hold the light assemblies in place. One set secures the headlight mount to the car front bumper. All these are supposed to be tight, with no slack. They have a 7/16 hex on them and are not for aligning or adjusting the headlights.
There are 3 screws that fit into sockets in the headlights. They are secured in place by C shaped spring clips. Two of the three screws are for aligning the headlights and have a 5/32" hex on one end. A third screw obtained from the junkyard may help in getting them aligned.
The adjustment screws are upper inside and lower outside screws. If the headlights were re-assembled properly, they will have a 5/32" hex on the screw. You can use a 1/4" ratchet with a 5/32" socket. The upper screws can be reached with the hood up, while the lower screws may require you to lay on the ground in front of the car and reach them from the bottom.
To align the headlights, find a level spot with a wall 25-30 feet away. Disconnect the driver light and align up the passenger light so that the light pattern is slightly below of the actual centerline of the headlight. This is to illuminate the right hand side of the road. Reconnect the driver light and disconnect the passenger light. The driver light should be aimed so that the light pattern on the wall is inward about 6" and slightly below the centerline of the headlight. This keeps you from blinding the oncoming cars. Disconnecting and reconnecting the headlights helps to show which headlight is shining in what direction. Reproduction headlights may shine in several directions at the same time, making it very difficult to align them if both lights are on at the same time
One Stangnetter recommends putting a fender cover over the headlight that isn't being aligned. I like his idea, it's simpler than disconnecting the lamps.
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
2010 V6 Sees differently than GT?
  • 6t9Mach1
  • Mar 31, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Apr 1, 2026
6t9Mach1
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
M
Hello all, I am new to this forum
  • Maddog 302
  • Dec 19, 2025
  • The Welcome Wagon
The Welcome Wagon Dec 20, 2025
nickyb
