HEADRESTS ???
  • Thread starter Thread starter Quick Pony
  • Start date Start date May 15, 2004
Quick Pony
129
Pensacola, Florida
May 15, 2004
  • May 15, 2004
What's the trick in removing the headrests in a 1991 convertable? I don't see any type of latch or button. They both go up and down freely, but won't come completely out of their holders.
Any help would be greatly appreciated.
Larry
BlueThunder1988
102
  • May 15, 2004
There is a clip that slides into a slot on the headrest shaft to stop it... you need to unzip the back seat cover at the bottom, put the head rest all the way up, lean the seat forward, reach up with a long standard screwdriver and wedge it between the clip and the headrest shaft. Once that's done, you should be able to reef the headrest off. Good luck!
G
Paint and Body Anyone know where to find the replacement /fix for this trim part on the GT vert?
  • gvanginkel403
  • Nov 14, 2025
Fox 5.0 Mustang Tech Nov 14, 2025
gvanginkel403
G
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
