heads and bore
spade33
198
Tempe, Arizona
so i have a question would the afr 165 cc heads fit on a 289 non roller motor? and if i did that and ended up getting them now could i switch the heads to a 302 out of a 89 later in life? or would that not be any good? also the motor i have i ugess in my 289 is bored 30 over? what exactly does that mean or change about the motor
All 289's are non-roller.
Yes, they should work on a later 302.
30 over is actually .030 inches of overbore in the cylinder. When the bores wear, they are overbored so the rings will seal and control the oil.
