I would go with MPH stage 2.5 heads reguardless. If staying N/A then get some VT stg 2 cams (high everlap..108ish....not good for blower as the inatke charge will excape through the exhaust...N/A the exhaust gasses help pull in fress air...increasing effeciency). If going blower then get custom grind MPH cams.
The comps can be used witha blower because their overlap (LCA) is lower (numerically higher) at 112 or so. this lets less boost excape through the exhaust and so is decently effecient both ways for the common user...its on that line between the two, N/A and S/C. If you are unsure about your future then the comp 270s are probably the best. But be warned, the 270s HAVE had a few cases of PTV contact...the VTs have had 0 that I know of.
