heads
  • Thread starter Thread starter aleborjas
  • Start date Start date Oct 13, 2005
aleborjas
610
  • Oct 13, 2005
hi wich heads are best for a 306-347 TFS TW, edelbrock RPM or canfield's?
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Oct 13, 2005
  • Oct 13, 2005
Depends on your application, and whether or not you have to take emissions. TW's are the only emissions legal ones out of that bunch you listed. The regular Performer heads are legal, but not the RPM.
aleborjas
610
  • Oct 14, 2005
here in venezuela we dont have emission controls here we need power here!
i whant heads for both aplications 306 and 347!
M
macx
228
SE Missouri near Cape Girardeau
Oct 14, 2005
  • Oct 14, 2005
For the 306, unless it's REALLY built up, the AFR 165's are hard to beat.
For the 347, the 185's are very good, as are the TF High Ports. For a step up from that even, bigger AFRs and also take a look at the Jegs/Kaase heads, real monsters!
On the Jegs catalogue website. jegs.com
I
IntenseBlue
946
  • Oct 15, 2005
AFR 185s.
Paul Perreca
1,085
  • Oct 15, 2005
I'd say Twisted Wedges - they have a cooler name lol
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Oct 15, 2005
  • Oct 15, 2005
AFR 165's for a 302/306. AFR 185's for a 347.
F
fox_bodies_rule
34
  • Oct 15, 2005
What 5sp GT said, if you are running a 347 the AFR 185's are perfect and they are smog legal; they have the port in the back for the air pump fittings and if you decide to go with a supercharger later on you are already set up-
my .02 worth
I
IntenseBlue
946
  • Oct 15, 2005
They'll work just as good on a 306 and way better on a 347.
aleborjas
610
#10
  • Oct 17, 2005
  • #10
i live in venezuela and whe dont have emissions controled vehicles and for my 306 and 185's wich intake is good and TB and inyectors?
what do you think RPMII and 70mm?
i aready have comp cams XE274HR its on the car and 30pound inyectors with 75mm maff its in my closet!
87'GTstang
1,025
#11
  • Oct 17, 2005
  • #11
For a 306 I would go with a mid-length runner intake manifold with a cam like that (assuming with what cam you have in it you will be revving higher in the powerband and are looking to go fast). Long runners (14" or so) are good for low-end but have little top-end: ie-the stock manifold, short runners (around 10" are poor for low-end but rev as high as the engine's supporting mods will allow ie- a box intake, TFS R, victor jr, ect. If you plan on running around town and haveing fun then something like a performer, TFS street or track heat, ect will do.
If you have a 75mm maf meter and do not plan on upgrading to a bigger one, then I would say go with a 75mm throttlebody, they can work rather well. However the drawback here is you have to look at the opening of the upper intake manifold you are using and see what size that is. It it is something like 70mm then going to a 75mm TB will be of no benefit if not harm a little - the key here is to port match the TB to the size of the opening on the manifold (but for a N/A 306 engine I would go no higher than a 75mm unit anyway)
30 pound injectors will carry an engine fairly well in the horsepower numbers (easily 400 territory).
I
IntenseBlue
946
#12
  • Oct 17, 2005
  • #12
Finally sounds like a match.
Fuel 1990 installing edelBrock intake
  • Beaker
  • Oct 5, 2026
Fox 5.0 Mustang Tech Oct 6, 2026
Engine What’s that?
  • PonyGTrider
  • Aug 24, 2026
Fox 5.0 Mustang Tech Aug 25, 2026
PonyGTrider
351W/5.8 EFI intake manifolds fading away...
  • Ryno5150
  • Jan 13, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 7, 2026
nickyb
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
