i eard that if you get rearended hard that the gas tank could liek spill and go forward and make a fire and stuff and make a wrose situation...is there anyway to prevent this???
Cobain03 said:i eard that if you get rearended hard that the gas tank could liek spill and go forward and make a fire and stuff and make a wrose situation...is there anyway to prevent this???
. Before that, I had an F100; the back tank was between the frame and the driveshaft (good), but the front tank was in the cab behind the seat (not good). Before that, a '73 Gran Torino. When "60 Minutes" did their piece on the infamous exploding Crown Vic/Police Interceptors; the "under-the-car" videos looked just like my '73. The layout was virtually identical - which would mean that, should I have gotten rear-ended by something going 50+ MPH, the gas tank would have ruptured when it was wrapped around the diff.
RacerX said:Either he was lucky or it's not as big a deal as it's made out to be but, his didn't catch fire or explode.
Cobain03 said:well,,this stang that im trying to find, is going to be my first car...
Edbert said:The same situation exists on the SN95s! I'd hazard a guess that the same thing is true for 90+% of the cars on the road.
67GTA-FB429 said:Also, Gas (liquid) does not burn. It is gas (vapor) that burns.
Not to split hairs...oh yeah, we already are...it is the vapor that is evaporating off of the liquid that flames not the liquid itself. The heat causes an increased evaporation rate, which burns faster, which makes more heat, which evaporates faster, which burns faster, which makes more heat, which....gp001 said:Gas doesn't burn ??? You mean if I pour some gas on the ground and throw a match on it it won't burn? It won't explode, but it'll burn.
