  • 1994 - 1995 Specific Tech
heater hose question??
  • Thread starter Thread starter fish254
  • Start date Start date Mar 8, 2009
F
fish254
237
Brooklyn NY
Mar 8, 2009
  • Mar 8, 2009
the two hoses that go to the fire i forgot the order in witch they go some help guys please???
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Mar 8, 2009
  • Mar 8, 2009
Seems like one is larger than the other
I believe if you look at things, it will be clear which goes where
Grady
Dino Dino Bambino
1,672
89
79
Cyprus
Mar 9, 2009
  • Mar 9, 2009
Yes indeed. One hose is 3/4" and the other is 5/8". The larger one goes closest to the passenger side fender.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Mar 9, 2009
  • Mar 9, 2009
It doesn't honestly matter which way the water goes through the heater core. As long as it fits and it doesn't leak.
Kurt
Adam95GT
2,564
Burlington, NJ
Mar 9, 2009
  • Mar 9, 2009
Kurt
one hose regulates pressure or something
divit250r
314
Columbia City, IN
Mar 10, 2009
  • Mar 10, 2009
One of the factory hoses does have a flow restrictor in it.
On an older F100, we accidentally reversed the heater hoses and you'd have thought the thing was going to blow up. Somehow the reversed fluid path caused the cores in the heater core to vibrate and moan. Strange, I know...
F
fish254
237
Brooklyn NY
Mar 11, 2009
  • Mar 11, 2009
no one really knows the order ha??
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Mar 11, 2009
  • Mar 11, 2009
Well ... Yes I know it
and
So do those who have read this thread
and
You too will know it if you look at the two different size hoses
Put the small one on the small barb
then
Put the larger one on the larger barb
If you trace the two hoses you will be seeing it just as Ford
made it available to the public
Just trying to show it is one of those things that can be fleshed
out with a small amount of common sense and a bit of
observation
Grady
99FiveOh
2,051
20
99
J-Ville, FL
Mar 12, 2009
  • Mar 12, 2009
I wasn't aware of any flow restrictor in Mustangs. I'll be replacing these hoses soon. Is it possible the restrictor is built into the heater pipe on the intake? I've had these hoses off on previous cars and they were just basic rubber hoses.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Mar 12, 2009
#10
  • Mar 12, 2009
  • #10
Over the years when this subject comes up
I've seen some say they found one in the OEM hose at the firewall
and
I've seen some say they found none in the OEM hose
I did not have one on my little 95GT
I rigged up one by using a small freeze plug with a hole in the middle
Grady
99FiveOh
2,051
20
99
J-Ville, FL
Mar 12, 2009
#11
  • Mar 12, 2009
  • #11
nice! I think I have one such freeze plug laying on my work bench, I might rig something up when I install the explorer engine.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Mar 12, 2009
#12
  • Mar 12, 2009
  • #12
I've never seen a flow restrictor on any of these hoses, and I've worked on a lot of these mustangs. I would say, that if you found a flow restrictor, it's something someone added later on. Either way, the hoses pretty much only fit on one way. If you get them backwards, it's going to look retarded, and one will be too tight, and the other will be too lose. I put a flow restrictor on my bypass hose. I never really saw a point in having a flow restrictor to the heater core.
Kurt
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Mar 13, 2009
#13
  • Mar 13, 2009
  • #13
I've found the plugs in many Ford products over the years
It is my understanding a reduced flow rate takes a bit
of the wear and tear off the heater core
Grady
L
Engine New guy heater hose question. 85 gt 4bbl.
  • linemech31
  • Jan 17, 2026
Fox 5.0 Mustang Tech Jan 20, 2026
General karthief
Engine Bleeding air in the heater core
  • keel
  • Apr 2, 2026
Fox 5.0 Mustang Tech Apr 23, 2026
limp
J
Mustang 1968 coupé restoration hvac
  • JackStang68
  • Mar 3, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
zookeeper
Engine Heater hose restrictor purpose
  • Mcmahst
  • May 5, 2025
Fox 5.0 Mustang Tech May 11, 2025
limp
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
