heater not working on my 65
  • Thread starter Thread starter stang 65
  • Start date Start date Feb 5, 2009
stang 65
  • Feb 5, 2009
heater blows cold , you can pinch the heater hoses, no water running to the core. i replaced the water pump, heater core and hoses, any help please.
suki243
662
Southern California
Feb 6, 2009
  • Feb 6, 2009
maybe the elbow coming out of the manifold has something stuck in it? or has rusted out.
shelby69
100
allentown
Feb 6, 2009
  • Feb 6, 2009
Make sure its not air-bound. That could make it not circulate well. Also, how about the thermostat. It is not stuck open is it?
Good Luck
stang 65
  • Feb 6, 2009
this morning , i took the hose off the the elbow that returns water to the block , and took a coat hanger and stuck it and rusty globs started seeping out then pretty green coolant , i knew then i found the problem. hooked the hose up and soon as the thermastat opened , i had heat. when i bought the car the the heater hoses were bypassed, for god knows how long. thanks for the replys.
Phil
suki243
662
Southern California
Feb 6, 2009
  • Feb 6, 2009
Nice! if that elbow is rusted though, i'd suggest replacing it; they're not too expensive. If it gets bad it will cause irregularities in the flow to the heater core, and it might cause that heater core to go bad in a few months. And as you probably know; they're a pita to replace. There was a thread earlier about it happening to someone else, they went through 2-3 heater cores before replacing the elbow.
P
I need definitive heater valve and AC expansion valve answers
  • PurAU
  • Sep 26, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 1, 2026
GypsyR
G
Engine Bleeding air in the heater core
  • keel
  • Apr 2, 2026
Fox 5.0 Mustang Tech Apr 23, 2026
limp
J
Mustang 1968 coupé restoration hvac
  • JackStang68
  • Mar 3, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
zookeeper
L
Engine New guy heater hose question. 85 gt 4bbl.
  • linemech31
  • Jan 17, 2026
Fox 5.0 Mustang Tech Jan 20, 2026
General karthief
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
