Hey fellas I need your help.
My buddy (also mechanic) just installed a C4 TCI streetfighter with 2400 TCI stall and 28 oz. flywheel.
It idles fine but when you get out on the road the damn thing vibrates the entire car. He checked the harmonic balancer and it is fine. ( the car ran fine before the trans swap). The 28 oz. fly is correct for this motor and trans (to make sure we did not get a bad fly wheel, I bought another and the same result).
We called up TCI they said its either the Torque converter, Balancer or flywheel so I guess we've narrowed it down to the Torque converter?
Has anyone else run into this problem after the trans swap? TCI also has a balancer they sell called the "Rattler" and I wanted to know if this balancer is worth the money?
Thanks
1966 Coupe
'68 302, 289 stock heads, 600 cfm Holley, 270H Cam
C4 TCI Streetfighter
Thanks
1966 Coupe
. If its not right I'll go with another converter. ITs getting to be to nice outside to be messing with new BROKEN equipment. I'll calm down now.
