First of all I live in Monterrey, Mexico. Unfortunately there are not that many shops that can give you a good and honest service. I bought about 2 years ago a Mustang Gt 96 Silver, Automatic Transmission, 75k Miles Aprox. till today.
Besides other problems, I just started experiencing the famous IDLE problem.
The first symptom I can recall was that until now if I turn the A/C, the temperature will keep rising till it gets to the red and dangerous line!
So I started switching the A/C on and off as required to prevent overheating.
A month ago the voltage or amp meter on the dash started to move either up or down, this was strange since I always check the dash, and the meter was always on the middle with or without the A/C on, lights switches or whatever. Also the temp. meter.
I took it to an electrical shop, and told me it was the alternator. They charged me around $180 dlls for parts and maintenance, change diodes, bearings etc........
After taking it out of the shop the problem remained the same. A few days later while on a freeway the car started to act crazy, the ABS indicator was lit, the odometer didn't move, neither the tach meter. I parked at a safe place, turn the car off and couldn't turn it back on, called Battery Master service and the guy told me the battery needed to be replaced. I replaced it hoping the problem would be solved but NO.
The car is frequently making strange movements while driving, like if it was running out of gas, not very dramatically but you can feel something is not right.
When I get to a stop sign or light, sometimes, usually when the car is kind of hot, the car starts to rumble like if it was to shut down. It has never shut down, but you can feel that is very close to do it. This is while on Drive, when this happens I switch to Parking and the rpm's go back to normal for a couple of seconds and then the problem comes back again. So it does it either on Drive or Park. The Check Engine is Lit and the guy at the shop has the code, hopefully I would get the code tomorrow and post it here.
I'll appreciate the help!
