HELP????? A/C Relays-WHere are they located???
avelleno
82
Guys,
Need HELP!!! please--i need to locate the Air Conditioning Relay??? Does anyone know-Where they are located on a 91 Stang??????
Any help-Is greatly appreciated!
Many Thanks-Anthony :nonono:
It should be behind the air box, down under the MAF if its like my 88. I remember a White/Pink wire that fried on mine. This is known as the WOT relay, as it cuts the AC when the puter sees WOT.I replaced about a foot of that wire that was all burned up and my AC has worked fine since.
blueMach said:
Jerry Beach is it possible you could post a picture of this relay?
thanks
Here's a pic of what the relay looks like on my 89.
Thanks Jerry! I thought that was it. Mine is burned also. It's an '88. Did you just splice the wire and tape it? I wonder if the whole section can be replaced? Mine is pretty bad.
Thanks again
