I listened to all your advice and today i decided to try to tackle my timing problems. Heres what you told me to do:
Take off number one cylinder plug
turn till compression
make sure timing is at 0
turn distributer till rotor faces #1 plug wire
adjust from there
I did all of that but I couldnt turn it till compression(kinda tricky unless you guys can clarify a lil), so i skipped that and went straight to #3. It took a while but eventually 0* came around. Then I took off distributer cap. The rotor was exactly 180* off. I turned it till it was as close as i could get it. After i put it all back together i tried to start but it doesnt work. Motors turns but never actually starts. Im guessing i messed up when skipping compression step, can anyone clarify what im doin at that point? What should I do?
adjust from there
