I need some help with my car, so if you know anything that might help let me know please.
I had my car put on a dyno yesterday to check my A/F Ratio. At idle it was sitting at 18.0!!
It didn't drop til nearly 4800rpm's and it never went below 16.1.
What can I do to make it not as lean?? I know I neeeed a tune, but I don't really have the money for a tuner/tune right now and probably wont for a while. Can I get a fuel pressure regulator for my car and up the psi and help solve the problem and where can you find one of those?? Or maybe bigger injectors??
Any info will be appreciated
It's for a bolt-on '02 GT 5-spd, by the way. (Mods in sig)
Please help me out Stangnet!!:SNSign:
It didn't drop til nearly 4800rpm's and it never went below 16.1. What can I do to make it not as lean?? I know I neeeed a tune, but I don't really have the money for a tuner/tune right now and probably wont for a while. Can I get a fuel pressure regulator for my car and up the psi and help solve the problem and where can you find one of those?? Or maybe bigger injectors??
. He didnt say the A/F, but I do know he shut it down mid run and then started tuning...so apparently it went way too lean. It was 14-15 before the cams, so I couldnt imagine. I would think a WOT A/F of 18-1 would melt the pistons, and he would no doubt hava ALOT of knock @ 16*s. Im also thinking that the A/F tool was jacked to an extent.
If you were running 18:1 at idle long term fuel trims would be at their limits and you would get a code. Check the plugs and see if they are showing lean. I would bet you are not off that much. A datalogger would be your best bet to check the fuel trims, but if you don't have one available, you can check your front o2 sensor voltage.
